Release notes: TNG Version 1.0.6.5
Postby Belinda Frick » Tue Apr 10, 2012 3:48 pm
TNG Version 1.0.6.5 (01 August 2009)
Features:
  • Department Configuration and Percentage Markup. A * prefixed to a value indicates a marked-up value.
  • Marked-up value added to end of export string.
  • The following alarms conditions will be emailed and displayed on the login page:
      Trunk Inactivity - Set per trunk on Trunk Configuration page
      Total Inactivity
      Reaching 90% of capacity
      Buffer not connected
      Subscription Expired
      Installation Invalid
      When the condition clears, an Alarm Clear will be send.
  • Alarm Configuration - This is off by default and must be configured to work.
  • Report Criteria now Supports Transferred Calls. Please Note this is PABX and plugin dependent.
  • Report Criteria now supports selecting Multiple Call Types.
  • Call Masking Configuration.
Fixes:
  • Numbers with non-numeric characters appended were not costed before.
  • Intermittent Re-registration Error Fixed.
  • Phonebook search display if only 1 entry in phonebook fixed.
