Release notes: TNG 1.0.7.6 to 1.1.1.6
Postby Belinda Frick » Thu Apr 12, 2012 3:27 pm
TNG Feature History
TNG Version 1.1.1.6 (5 April 2012)
    Changes:
  • Licensing changed so that subscription licensing can now be done over the phone.
  • Asterisk version replaced with TNGLive.
  • TNGLive can now be permanently activated.
  • Buffered TNG no longer stops loading calls if a buffer is not found, it only disables functionality the same as TNGLive.
  • Added work-around for an issue with the Chrome web browser where trunks are wiped out after applying settings. Problem seen on Chrome versions 16 and 18.
TNG Version 1.1.0.8 (30 November 2011)
    Changes:
  • Fixed two bugs in buffered TNG on Linux where TNG would crash.
TNG Version 1.1.0.7 (28 October 2011)
    Changes:
  • Fix for TNGLive where the TNGLive might deactivate
  • When leaving the scheduled reports without applying changes, the user is asked whether to save or cancel.
  • Live updates now use much less CPU on the TNG server.
  • Pin code usernames are no longer used in automatic extension updates. This fixes a bug where the department on the extension would change to the pin code user's department.
TNG Version 1.1.0.5 (14 October 2011)
    Changes:
  • Added support for configuring serial settings.
  • Minor changes for TNGLive activation.
TNG Version 1.1.0.0 (30 September 2011)
    Changes:
  • First release of TNGLive: see TNGLive web site.
  • Minor javascript fix for department edit when leaving the screen and clicking OK to save changes.
TNG Version 1.0.7.7 (17 August 2011)
    Changes:
  • Better support for Asterisk 1.6 and 1.8.
