- Code: Select all
C:\Program Files\datatex\tng
TNG has no option to deleted the entire phone book. You can only delete single entries - one at a time.
Possible reasons why the phone book is blank (phonebook entries missing):
- If the 'destinations.txt' file got deleted from the TNG folder. This can only be done manually or for example done by anti-virus software that saw it as a thread.
- If you re-installed TNG without uninstalling and backing up the older TNG folder. It will then replace the entire TNG folder (including the destinations.txt file) with blank files.
Should you need to re-install/move TNG, please follow steps:
How do I move/re-install TNG?
