You require the program "ConvertTopazToTNG.exe":
- Close TOPAZ.
- Run it on the PC where Topaz is installed.
- Click the Convert button.There should now be 2 files in your Topaz 'data' folder called:
- tngext.dat
- tngusers.dat
- Code: Select all
C:\Program Files\datatex\topaz\data
- Stop the TNG Service
- Copy the new files into the DATA folder in the TNG folder:
- Code: Select all
C:\Program Files\datatex\tng\data
NOTE: this will replace all setup already done for extension and pin codes. - Start TNG Service.
