You need to change the line/trunk value of 'LINE' to for example '0'.
- Create a text file with the name 'Rules.ini'.
Add the following in the body of the file:- Code: Select all
[PluginRules]
Internal=1
0=LINE|EQUALS|LINE|0|TRUE
This rule will check if the trunk/line value is 'LINE' and then change it to '0'. - Installing the plugin rule:
STOP the TNG service.
Paste Rules.ini into your TNG plugins folder. (C:\Program files\datatex\tng\plugins).
START the TNG service.
