Does TNGLive work with Asterisk?
Postby Belinda Frick » Mon Sep 03, 2012 10:43 am
TNGLive(up to version 1.1.1.8) does not have an Asterisk integration, but we have a TNG for Asterisk version. This version has a 30 day trial period, thereafter needs to be purchased and has an annual renewal fee(if not renewed it will still load new calls, but you cannot run any TNG updates).
If you wish to install TNG for Asterisk, you can download the install from our website:
http://www.datatex.co.za/datatex_web_9_007.htm
Go to the ‘TNG for Asterisk’ section and use the download link “TNG for Asterisk Linux version 1.0.7.0”.
NOTE: It will expire in 30 days. When installing, please rename the master.csv file so that you only have current call details in it – else it will expire. You can thus run it for a 30 day trial period. Thereafter you need to purchase it.
For configuration required on the Asterisk side, please see forum post:
TNG: Asterisk output configuration required
You will need to register on the forum and be logged in to download the manual.
forums.datatex.co.za
For the TNG for Asterisk user manual, refer forum post:
Where do I find my TNG installation guide/user manual?
To upgrade to TNGLive for Asterisk - see forum post: TNG 4* update 2012
