How do I update my 'tngext.dat' extensions to another branch
Postby Belinda Frick » Tue Oct 30, 2012 1:02 pm
I have 2 TNG and need the extensions configured in both for another branch's TNG. I want to merge two 'tngext.dat' files. How do I do it?
There is no option to merge .dat files in TNG. You can import the extension list, refer to forum post:
How do I import extensions from a file into TNG?
You can export the extension of the 'tngext.dat' file you want to merge to CSV. Follow these steps:
  • Go to the 'Reports' page.
  • Select the 'Extension Listing' under the 'System Reports' section.
  • Use 'Preview' to see if all extensions are listed. If so, close the report and then use 'Export CSV'.
  • You will now get the option to save to CSV. This is a comman delimited CSV file. Each column entry is in double quotes and seperated by a ','. You can edit this file in a plain text editor. Remove the double quotes and replace the ',' with a '|'.
  • Once in the correct format, use the import extensions option, refer to post:
