How do I install PABX3 from the TNG install CD?
Postby Belinda Frick » Mon Nov 19, 2012 12:53 pm
PABX3 is on the TNG install CD in the tools folder. You can copy the entire PABX3 folder from the TNG install CD to the folder: 'C:\Program Files\datatex\'. Go to the PABX3 and double-click on the 'pabx3.exe' file to run it. In the bottom right-hand corner the PABX3 icon will be displayed. Right-click on it and select 'Show'.
  • Serial Connection:
    Options -> Communications, select (1-4) or enter the com port number and PC baudrate will be either 9600 or 19200. Click on 'Save' to enable changes made.
  • Network Connection:
    Options -> Network, tick TCP connect and enter the IP and port.
If you do not have the TNG install CD, download and unrar the file:
PABX3.rar
NOTE: upto TNG install 1.0.7.6 received before 20121119, the PABX3 version did not have the TCP connect option. Please download the PABX3 attached to this forum post.
Re: How do I install PABX3 from the TNG install CD?
Postby Belinda Frick » Mon Jan 27, 2014 10:11 am
How do I configure PABX3 to log rawdata?
Why is my rawdata not logging to file?
