How do I view a abuse report per extension?
Postby Belinda Frick » Mon Feb 11, 2013 11:20 am
    The abuse report will list calls made within a department that meets your 'Abused Call Criteria':
    It will list each department sperately and then the abuse calls within it.
    NOTE: The calls is sorted by date and time (and not per extension).
Abuse report per extension:
    If you whish to see the calls grouped per extension, you need to create an Abuse call report per extension within the department.
    Example of report:
    This needs to be done for each extension number you need abuse reports for. You can setup all the reports in a schedule. Once in place the e-mail of reports will then be automated.
    See forum post: TNG and scheduled reports/archiving reports
Re: How do I view a abuse report per extension?
Postby Belinda Frick » Thu Feb 19, 2015 4:02 pm
Find attached forum post in pdf format:
abuse report per extension_.pdf
