Release notes: TNG version 1.0.7.0
Postby Belinda Frick » Thu Feb 21, 2013 3:14 pm
TNG Version 1.0.7.0 (01 May 2010)
    Features:
    Changing of historical call information is now supported.
    Fields that can be changed are extension, pinuser, account, trunk and destination names and department, phonebook category and private or business call.
    PLEASE NOTE:
    Inconsistent report data will result when using this feature.
    Scheduled reports can now be modified.
    TNG can use a different currency than the one set on your computer. This is changed in the General Settings screen.
    Support for Datatex MyAccount system through the MyLink field in the Phonebook.
    The date range selector on the report criteria page will now default to "Time Range" instead of "Daily Interval".
    We have found that users change the times on the selectors unaware of the filtering affect it might have under the "Daily Interval" option.
    Rate updates:
    VOX
    Indonesia
    Malawi
    Telkom
    Mauritius
    Namibia
    Fixes:
    Adding an extension range with a zero prefix, e.g 001 to 100, was dropping the leading zero(s).
    Deleted scheduled reports still tried to execute and then failed with a log entry.
    A recost bug introduced in version 1.0.6.5 might stop TNG from processing calls and not recover.
    Certain email servers displays the JavaScript in the embedded report email. We have now removed the JavaScript from the embedded report.
    TNG4Asterisk: Very busy Asterisk sites might have performance issues when running TNG due to slow reading. We changed the way TNG reads from the Asterisk Manager Interface to improve it significantly.
    Technical:
    Data Flushing Interval changed to allow for changing the date and time on the PC.
    If the date or time was set in the future and then changed to the correct date and time, flushing might not be triggered.
    Loading call data will strip invalid characters it might have saved in prior versions.
    On loading the extension, pinusers, accounts and trunk data from disk, TNG will now first check if the file versions match the calldata version before loading it.
    Previously this data was loaded and a version mismatch could have caused corrupt calldata.
NOTE:
  • This upgrade is for South-Africa. Save on the TNG Server and double-click on the .dtx to run the update. It will stop the service, upgrade the TNG and start the service. Download and unrar:
    tng-za-rates-1_0_7_0.rar
  • TNG Botswana Rates update 2011 (Windows version)
If your TNG expires after 01 May 2010, you will not be able to run this update.
