Release notes TNG version 1.0.6.2
Postby Belinda Frick » Tue Feb 26, 2013 12:00 pm
Download and unrar (note TNG for South Africa - Windows):
TNG_za_1.0.6.2_Update.rar
To upgrade: Save the extracted file (.dtx) on your TNG PC, double-click to run. It will stop the TNG service, upgrade TNG and start the TNG service again.
TNG Version 1.0.6.2 (22 January 2009)
Features:
Busy Hour Reports added.
Transaction Report added.
Ratebooks for Namibia added.
Recosted calls will be re-exported to the exportfile for TNG Enterprise Support.
TNG 4 Asterisk will now also attempt to reconnect to Asterisk when receiving a Socket Disconnect error.
TNG Version 1.0.6.1 (9 September 2008)
Fixes:
Startup problem on Linux distributions with not IP address assigned to ETH0.
TNG Version 1.0.6.0 (10 September 2008)
Features:
NB: TNG's export file names and locations have been changed.
Exports will now happen to a day-stamped file directly in the export folder and a day-stamped folder will not be created anymore e.g:
c:\program files\datatex\tng\export\20080910.txt
or Linux:
/opt/datatex/tng/export/20080910.txt
Additional information has been added at the back of the export data format.
Additional Options was added to the Call Outcome selection criteria for reports.
TNG now supports co-branding. Dealers can contact our Sales Office for more information.
The Speed of browsing the user interface over a WAN has been improved.
A TCP Keep Alive option has been added to provide earlier detection when a connection to a network PABX has been dropped.
Changing the TCP Listen ports for integration will now take affect without having to restart TNG.
The minimum percentage of memory to use for TNG has been decreased to 5% on Linux.
Ratebook and Exchange File versions are now written to logfile when the file is loaded.
The Message displaying remaining and stored data on the Login page has been made more descriptive.
Additional Information Logs pertaining call saving and loading has been added.
Plugin rules can now be configured to also apply to internal calls.
Support for the TNG Barring Utility was built in.
Support for the TNG Enterprise Edition was built in.
Fixes:
The call record sequence number will only increment when a call has been validly parsed as a new call.
The bug introduced in version 1.0.5.8 whereby you were unable to delete extensions has been fixed.
Reports will be checked for validity before the report is generated for example when a refresh is done.
This was a problem under certain Linux distributions which could have caused TNG to crash.
TNG Version 1.0.5.8 (26 May 2008)
Features:
TNG now allows for the import of extensions. See help or contact support for more Information.
TNG Version 1.0.5.7 (15 April 2008)
Features:
TNG now allows for the setup of customrates. See the help link on the custom rates edit page for more information.
Exchange mapping to calls optimized
TNG Version 1.0.5.6 (28 March 2008)
Features:
TNG Standard version now also provide File Read as an alternative to Serial or Network communications.
When selecting this option you also need to specify a path and filename or filename mask using the * character.
Examples:
c:\mypabxdata\*.txt >>> will process all txt files in the c:\mypabxdata\ folder.
c:\mypabxdata\RAWDATA.txt >>> will process the RAWDATA.txt file in the c:\mypabxdata\ folder.
c:\mypabxdata\Week*.txt >>> will process all txt files in the c:\mypabxdata\ folder that starts with Week.
c:\mypabxdata\* >>> will process all files in the c:\mypabxdata\ folder.
Please Note that any files matching the mask will be processed and moved to the processed folder at night.
Fixes:
Memory Leak when duplicate records were detected fixed.
TNG Version 1.0.5.5 (11 March 2008)
Features:
Calendar can now quick select the month or year when double clicking on the Month Year Caption.
Report Search Criteria now allows for typing in an Account Code where applicable
Trunks can now be selected on the Trunk Utilization Report
The Trunk Field was added to the CSV Export format of the applicable detailed reports.
Faster Report generation on the Department and Trunk Summary Reports.
Write a log entry if error occurred while loading ratebooks.
Duration will now always be stored in the format hh:mm:ss
Extension Number and Line Number length changed from 10 to 25.
Additional Exchange Zones added into exchange file.
Fixes:
TOP X Duration Report not sorting correctly if duration stored in both h:mm:ss and hh:mm:ss format.
Pin user names longer than 20 characters not displaying data if generating report from the live call list page.
Blank entries in the data can no longer exist and use up memory space.
Export to CSV Report correctly handled with MS Excel 2007.
Deleting a newly created department from the list gives an error when applying the page changes.
Department Head and Admin logins and user ageing not releasing locks on Department Head Configuration.
TNG 4 Asterisk now allows for selecting a different file after processing another on the same day.
TNG 4 Asterisk can now search for the word OUTGOING in the number field of reports.
Negative Ring Times will be defaulted to 0.
TNG Version 1.0.5.1 (10 December 2007)
Features:
Standardation of TNG to use the YYYY-MM-DD HH:NN:SS Date Format.
TNG 4 Asterisk Asterisk CSV File Import changes to allow for blank destinations.
TNG Version 1.0.5.0 (30 November 2007)
Features:
An option for Page Breaks is now available on applicable reports.
TNG 4 Asterisk now allows for reading data from the Asterisk CSV file.
Raw logging will be enabled by default on a new installation.
TNG will try and recover older data files from the data folder if it can't find the correct one.
Fixes:
TNG 4 Asterisk user lookup failure when using accountcodes as pincodes.
TNG Version 1.0.4.6 (Standard) (09 November 2007)
Fixes:
Error on Enabling Raw Logging fixed.
TNG Version 1.0.4.5 (25 October 2007)
Features:
New features link displaying TNG history (This page).
Extension List Report added under System Reports.
PIN User List Report added under System Reports.
Account Code List Report added under System Reports.
Trunk List Report added under System Reports.
Trunk Configuration in ranges now allow for adding a prefix.
Detailed Reports now also include call counts.
Only Flush Call data if changes were made to the database i.e Recost or new calls received.
On TNG 4 Asterisk, Enabling raw data logging will reconnect to Asterisk to get the configuration data.
Fixes:
Buffer detection freezing on USB to Serial Converters.
Slow loading of calldata on startup in Linux.
Possibility of Call Purge causing call downloading to stop.
TNG Version 1.0.4.0 (30 July 2007)
Features:
Report Achiving.
Call capacity status bar on live call list screen.
Call capacity status and estimated range display on login screen.
Trunk Occupancy report added.
Extension Occupancy report added.
Option to update extnames from PABX data if supported by the PABX.
Default Ratebook selectable on trunk config screen.
Asterisk support for FreePBX
Improved System verification.
Faster Buffer detection.
Buffer disconnected alert when detecting disconnecting buffer while TNG running.
You can now email reports generated from the live call list screen.
Reference field added and exported as last field.
Ratebooks for Kenya added.
Fixes:
Asterisk restart re-connection fail fixed.
Linux Systems with more than 2 GB memory available calculation.
Trunk Distribution report not hiding detail when manually selecting to hide it.
Re-licensing expired systems not reactivating ratebooks.
Purge data memory leak fixed
TNG Version 1.0.3.0
Features
Asterisk event logs written when Logging Raw data is enabled.
Asterisk allowing for authorization codes.
Write Logs now including the version number
Asterisk exception, connect and disconnect logging added
Total Duration Column added to Department Summary reports.
Images used for drilldown reports instead of +- text.
Finding Buffer function will refresh the comport list to find buffer in.
More logging information when opening comm ports.
Fixes
Latin characters not displaying on live screen and URL’s fixed.
Unrestricted Department head can't change extension department within allowed departments in IE fixed.
Firefox general setting page asterisk info display fixed.
New Department head creation bug fixed with incorrect saving on restart of PC.
TNG Version 1.0.2.0
Features
Report Scheduling added
Report CSV Export added
Switch to capture raw data to raw.txt added
Recosting function improved
Report Data to sort numeric first then alphanumeric
Maximum memory limit changed to 2gb from 1gb
Adding Trunk by range now allow for entering a description and ratebook.
Asterisk interface added
VOIP-INT and VOIP-EXT added for "trunkless" VOIP calls on Asterisk. They will always be costed zero unless a different ratebook specified
Admin user now also remember last reportdates like Department Heads.
TNG Version 1.0.1.0 - First Commercial Release
