TNG export options
TNG export options
Postby Belinda Frick » Tue Apr 02, 2013 4:21 pm
  1. You can export the call details to a port or file (automatic: exported as call records imported to TNG)- see forum post: TNG EXPORT STRING FORMAT
  2. You can export the TNG reports to CSV file(manual process).
    see forum post: Can I export TNG reports to Excell?
You can use either export option. Note that TNG does not do integration with Third Party Software, we only export into a standard format to allow you to do further integration.
