Release notes: version 1.1 to 1.1.1.11
Postby Belinda Frick » Tue May 14, 2013 11:12 am
TNG Version 1.1.1.11 (11 December 2012)
Changes:
Fixed bug in TNGLive where TNG locks up during file import.
TNG Version 1.1.1.10 (6 December 2012)
Changes:
Fixed bug where Department markup could not be edited.
TNG Version 1.1.1.9 (6 November 2012)
Changes:
Buffer check is now done before connecting to PABX and processing of data.
Fixed bugs in permanent activation code.
TNG Version 1.1.1.8 (25 April 2012)
Changes:
TNG now disconnects and reconnects to a network PABX at 4am every morning.
A new setting named "Idle Disconnect" can be enabled, which causes TNG to disconnect and reconnect to a network PABX after 60 minutes of no activity. This will only happen during working hours.
TNG Version 1.1.1.7 (12 April 2012)
Changes:
Licensing changed so that subscription licensing can now be done over the phone.
Asterisk version replaced with TNGLive.
TNGLive can now be permanently activated.
Buffered TNG no longer stops loading calls if a buffer is not found, it only disables functionality the same as TNGLive.
Added work-around for an issue with the Chrome web browser where trunks are wiped out after applying settings. Problem seen on Chrome versions 16 and 18.
TNG Version 1.1.0.8 (30 November 2011)
Changes:
Fixed two bugs in buffered TNG on Linux where TNG would crash.
TNG Version 1.1.0.7 (28 October 2011)
Changes:
Fix for TNGLive where the TNGLive might deactivate
When leaving the scheduled reports without applying changes, the user is asked whether to save or cancel.
Live updates now use much less CPU on the TNG server.
Pin code usernames are no longer used in automatic extension updates. This fixes a bug where the department on the extension would change to the pin code user's department.
TNG Version 1.1.0.5 (14 October 2011)
Changes:
Added support for configuring serial settings.
Minor changes for TNGLive activation.
TNG Version 1.1.0.0 (30 September 2011)
Changes:
First release of TNGLive: see TNGLive web site.
Minor javascript fix for department edit when leaving the screen and clicking OK to save changes.
