When I run the update 1.0.7.6 I get the error message
- Code: Select all
Extractupdate.exe has stopped working.
I am using Windows 7. The PC is not on the domain and is in the work-group. No user account control settings is in place.
I do not have the option to run as administrator.
Solution:
- To ensure you are running the update as administrator:
- Open command prompt.
- It must show administrator on the top left-hand side of the black box. If it does not show 'administrator' then another user is logged in and you will not have administrator rights.
Navigate to 'C:\Program Files\datatex\tng\update'.
Enter the dtx update name and press enter to run it.
- If you still get the same error message, try fhe following:
Please unrar and save the file in the 'C:\Program Files\datatex\tng\update' folder:
Run the update again
