Which update to use?
- If you have a buffer connected, or a version prior to 1.1.1.1, you require the normal TNG Update.
- If your TNG requires internet access, you don't have a buffer, and/or it states TNGLive on the header banner of your Web interface, you require the TNGLive update.
- If you are running a TNG 4*, these 2 updates will not work on them. We will do a separate release and update this post. Also know that the TNG 4* is now only supported with an installation directly on the Asterisk server.
The following changes are available in the 1.1.1.12 update.
- Telkom Rates Aug 2013
- Custom_simple Rates
- TNG 1.1.1.12
The following changes are available in the 1.1.1.12 Install.
- Updated Exchange Libraries
- Botswana BTC Rates
- New PBX support (Plugins)
- New Buffer drivers
- TNG 1.1.1.12 can send non-plain text characters as login details to Network PBXs
Buffer
- Drivers that support Buffer version 1.08
- 32Bit and 64Bit
- Supports Windows 8 and Server 2012
- Major update of other operator destinations, rate codes and international destinations.
- Includes new VOIP Numbers ranges and Cellular number ranges
- SupremeCall 1000 = R200, R300, R500, R1000, R1750 and R2500
- SupremeCall 8000 = R4000, R6000 and R8000
- SupremeCall 10000 = R10000, R12000 and R15000
- SupremeCall 18000 = R18000
- SupremeCall 20000 = R20000 through R300000
Exchange Libraries
- Major update of exchange names and numbers
- Many new International and local destination descriptions
Botswana BTC Rates
- If the number is shorter than 5 digits, the local area code is added to the number to allow lookup of the number.
- The correct cellular number ranges has been added.
- New VOIP Number ranges have been added.
Custom Rates
- Custom and Custom_Simple rates have been recompiled for 1.1.1.12
- Both rates have been compiled for Linux as well
- Most of the cellular providers' rates files have been replaced with Custom_Simple rates configuration files to allow easier updates
More details on how to configure your own rates here
Plugins (Installation only)
- PAastra_A470_Format_PC5 (PC5 Format)
- PAlcatel_OXO_OmniPCX_Office (Better valid data checks)
- PAudiocodes_Mediant_Pipe (Example INI file included)
- PAvaya_IP_Office (Can handle pin codes and account codes at the same time)
- PMitel5000 (Mitel 5000 plugin requires TNG 1.1.1.12 and the SMDR password from the PBX)
- PPanasonicTES824 (Handle Incoming CLI)
- PanasonicTDA.dll (Better handling of short phone numbers)
- PNEC_IPC100_S70H_R501 (Can be configured to swap month and day around)
- Previously missing plugin references has been fixed
- PAlcaltel_OXO
- PBTVersatility
- PConvergence30
- PIntertel_CS5000
- PLGGDK100
- PLGGDK162
- PLGGDKFPII
- PLGOpticon
- POfficelink
- PSamsungDCSCompactII
- PSamsungPlastic
- PSiemens118
- PanasonicKXTD816
- PanasonicTEA824
- PanasonicTES824
Updates- You have to be on version 1.0.7.6 at least to be able to use this update.
- tng-update-1_1_1_12
- tnglive-update-1_1_1_12
To update for example 'tnglive-update-1_1_1_12':- Right-click and save the file onto the Asterisk server.
- Navigate to folder where it was saved and use the command to make it an executable:
- Code: Select all
chmod +x tnglive-update-1_1_1_12
- run the update:
- Code: Select all
./tnglive-update-1_1_1_12
For 1.0.7.6 update see TNG: Why is my 8TA calls costing at zero?
For windows
For Linux ("chmod +x" the file and run it to upgrade)
Right Click these files and select the Save option, not just click on them, it will try and display the file.
- For Windows
- TNG_setup_1_1_1_12.exe(with buffer)
- TNGLive_setup_1_1_1_12.exe
- tng-1.1.1.12-1_all.deb(TNG with buffer)
NOTE: The plugins are not included. Please find out your PABX brand and model from your PABX vendor. You can register on the forum and post a request for the plugin. - tnglive-1.1.1.12-1_all.deb(TNG for Asterisk)
For Linux (Ubuntu/Debian)
If you installed the wrong update:
Installing the TNGLive update on a TNG with a buffer, will put your TNG in Free mode with limited features. Please just run the Buffer upgrade to fix it.
Installing the TNG with buffer update on a TNGLive, will have the TNG searching for a buffer and never starting properly. Please just run the TNGLive update to fix it.
