When I install TNG, I get the error message failed to rename C:\Program.....\tng.exe
Try the following:
The error message points to either:
- permission
- the install was not run as administrator
- the directory or tng.exe already existed and another user has access.
Please check that you have full install rights.
If TNG is not listed as a service, rename the 'datatex' folder.
Run the install as administrator.
If you still have issues, download the install from our website:
Latest update releases of TNG - as of 2013-08-01
TNG Update 1.1.1.12
If you still get the same errors your permission to install is still not in place.
