CAN ONLY BE UNINSTALLED ON 64-BIT WINDOWS
Postby Belinda Frick » Wed May 28, 2014 12:57 pm
I have a 32 BIT PC with Windows 7, when I use the TNG uninstall program or Windows ADD/REMOVE, I get a message CAN ONLY BE UNINSTALLED ON 64-BIT WINDOWS
Solution:
Do the uninstall on command line:
Open Windows prompt and navigate to folder:
C:\Program Files\Datatex\tng
Type the command:
tng.exe -uninstall
