Windows server cannot find USB drivers on install
Postby Belinda Frick » Wed Oct 22, 2014 12:10 pm
When I install or update TNG drivers on a Windows server edision, Windows gives a message that it cannot find the drivers. I can navigate to the drivers, but it does not regocnise it.
If you have buffer with the older programming (before Windows 8), the buffer will not be detected when you plug it in and check in Windows with Device Manager under Universal Serial Buss Controllers. You need to update the buffer programming so that Windows 8 can see the device.
For buffer programming tool, refer to forum post:
TNG USB Buffer on Windows 8 and newer
