Which plugin does the Panasonic NS1000 use?
Postby Belinda Frick » Mon Jun 08, 2015 3:59 pm
The format of the rawdata is the same as the Panasonic TDA.
Which plugin do I use for the Panasonic TDA?
This PABX however uses a login.
You can configure the login and command under the 'authentication information' option in the 'Communication Mode' section.
Please see screenshot for configuration and adjust according to:
your login and password aswell
as network IP and port of PABX:
Re: Which plugin does the Panasonic NS1000 use?
Postby Belinda Frick » Thu Jun 15, 2017 10:59 am
Panasonic technician confirmed that the Panasonic TDA plugin also works with the Panasonic NS500.
Postby kebogile Porogo » Mon Jul 30, 2018 12:36 pm
Panasonic NS500
In the authentication information field, copy & paste the below as in the screen shot.
Authentication Information
[CRLF]SMDR[CRLF]PCCSMDR[CRLF]
kebogile Porogo
