MITEL Baring No NIC is provided, attempting to select one
Postby John Richard Procter » Fri Oct 28, 2016 3:55 pm
Scenario:
The server where the Mitel baring is installed on has two network cards.
Mitai connection is not working to the PABX beacuse is cannot determine which network adapter to use.
15:45:42.290, 10/28/2016 (pid 3980): No NIC is provided, attempting to select one.
15:45:44.973, 10/28/2016 (pid 3980): connect() in ssumtai__basic_client failed for PBX 172.80.6.2 with err= 10061.
15:45:44.973, 10/28/2016 (pid 3980): Socket Connect has failed for PBX 172.80.6.2
15:45:44.973, 10/28/2016 (pid 3980): Creation of MiSocketTCP failed, fatal !
15:45:44.973, 10/28/2016 (pid 3980): SSL handshake in mi_socket_open failed for PBX 172.80.6.2
15:45:44.973, 10/28/2016 (pid 3980): ssumtai_disconnect - Cannot find Pbx Object Error.
15:45:44.973, 10/28/2016 (pid 3980): Aborting SXOpenPBX -- could not attach to pbx 172.80.6.2
15:46:42.303, 10/28/2016 (pid 3980): Entering SXOpenPBX.
Resolution:
Mitel barring update version 1.0.4.1 (MiTAI 5)
tng-MitelBarring-install-1_0_4_1.rar
