Plugin: 3CX version 14
Postby Belinda Frick » Fri Jul 21, 2017 10:50 am
PABX output format:
CDR file
Field names and sequence:
historyid,callid,duration,time-start,time-answered,time-end,reason-terminated,from-no,to-no,from-dn,to-dn,dial-no,reason-changed,final-number,final-dn,bill-code,bill-rate ,bill-cost,bill-name,chain,from-type,to-type,final-type,from-dispname,to-dispname,final-dispname,
outgoing normal
Example of raw data:
Outgoing call:
Call 3703,00000BEB9273C926_3159,0.00:00:04,2016/04/29 11:18,2016/04/29 11:18,2016/04/29 11:18,TerminatedByDst,Ext.576,27716800339,576,10000,716800339,,,,,1,0,7,default,Chain: Ext.576;0716800339;,Extension,Line,,Paul Slabbert,27716800339,
outgoing unanswered,,,,,,,,,,,,,,,,,,,,,,,,,,
Plugin:
P3CX.rar
Configuration required:
  1. Also add this line on your rules.ini file
    2=NUMBER|STARTS|27|0|FALSE
    It strips of extra 27. This file is in the 'C:\Program Files (x86)\Datatex\tng\plugins' folder.
  2. NOTE: Place P3cx.dll in the folder :
    STOP/START then TNG service.
    You then need to log into TNG as 'admin'.
    Select 'General Settings' (and enter technical password - else no access to update any settings)
    Under 'Communication Configuration' select 'P3CX' from the drop-down for Plugins.
    Click on Apply to save.
  3. Check the version number.
    It must be at least : 2016.05.05.1
Re: Plugin: 3CX version 14
Postby Leon van Heerden » Wed Sep 12, 2018 12:04 pm
Version 2017.07.24.1
* Added 3cx.ini in the folder where the application executed from.
This file contains the default date format. If the date format in the rawdata and this file is not the same, the current system date and time is used when it tries to read the START, END and ANSWER dates.
OPTIONS
DateFormat=YYYY-MM-DD
Ensure that you change this format to the same format from the rawdata file.
* Added Ring Time Calculations
* Added unanswered Call check on transferred incoming call.
* Added extra LineSet and Line Checks for other LINE variables to help show Outgoing calls.
Version 2018.09.12.1
* Added the date format to the ring-time calculations.
P3CX-20180912.rar
