TNG and Mitel: all my calls cost at zero
Postby Belinda Frick » Wed Feb 27, 2019 5:04 pm
I am running TNG 1.1.1.12
All my calls cost at zero.
I have a Mitel PABX.
On the Call List page all calls have zero cost.
My trunk/lines all shows as INTERNAL.
OVERVIEW:
Ensure the lastest version of the Mitel plugin is used(at least version 2015.10.16 and up)
Which plugin do I use for the Mitel 3300 ICP PABX?
It will create a file 'PMitel_3300icp_Certified.ini'
in the folder 'C:\Program Files (x86)\datatex\tng'
Stop the TNG service.
Edit the file and update the setting NOINTERNALTRUNKS to '1':
[OPTIONS]
COMBINEFORWARDRECORDS=0
NOINTERNALTRUNKS=1
Start the TNG service.
Make an outgoing test call and ensure it has a duration.
Check that the trunk shows as Y9999 and has a cost.
