Topaz Next Generation (TNG.exe) released. Version : 1.0.4.5
Postby Belinda Frick » Mon Nov 15, 2010 10:01 am
TNG update 1.0.4.5
The following features have been incorporated into TNG this month:
There is now a link on the TNG login page that will display all
the past and new features that have been incorporated in TNG.
System reports:
An extension list report has been added which will provide a list of all the extension numbers in TNG.
Departments can be specified with optional criteria to only display the extensions within the department selected.
If no department is selected it will include ALL the extension numbers.
A pin user report has been added to display a list of all the pin code users in TNG.
This list can be broken down to view only the users of a particular department
or alternatively all the users can be listed.
An account code list report has also been made available to display a list of
all the account numbers and account names in TNG.
A report has been designed to list the trunk numbers, trunk names or the rate book associated to the trunks in TNG.
All the above mentioned reports are available under the system reports section on the reports page.
Detailed reports now also include call counts.
Trunk line configuration:
When configuring trunk ranges in TNG it is now possible to allocate a prefix for a trunk line.
TNG4*
On TNG for asterisk, enabling raw data logging on the general settings page will
reconnect to Asterisk to get the configuration data.
Fixes in TNG 1.0.4.5:
When using a USB to serial converter it would cause TNG to freeze during buffer detection. This has been fixed in this update.
When starting TNG on a Linux server, it would cause the loading of call data to be slow, this has been addressed.
Previously during a purge it would be possible that the purge process would stop calls from being loaded,
this has been fixed in this version.
In order to receive this update for TNG make sure that your TNG software has been registered.
Should you require instructions on how to register you may contact support@datatex.co.za or
visit our website www.datatex.co.za and download the TNG users guide.
