My PC crashed. TNG is unlicensed.
Postby Belinda Frick » Mon Nov 15, 2010 1:23 pm
Make a backup copy of the Data folder located in
C:\Program Files\Datatex\TNG\
Reinstall the new TNG,
Enter the new installation serial number
After TNG started up and is working stop the service
Start - Control Panel - Administrative Tools - Services
Copy the previous versions .dat file in the
C:\Program Files\Datatex\TNG\Data\ folder.
In the INI edit the loc=
This is the last place that TNG saved data. Change it to the
number of the file just pasted in, without the extension field. (No .dat file extension)
[DATA]
Interval=300
loc=1data_1.0.3.0
Memory=10
Version=1.0.4.4
Save the ini and start up TNG.
TNG will now look in the last place it saved data which is the loc= field in the [DATA] section of the INI.
