Overview
TNG was developed to limit failure points, therefore it only allow one
source of data input. You can select one of the two communication modes,
Serial or Network. For each PABX unit you will need to install a TNG.
How do I view data from a different branch?
You will be able to access the other branch TNG through your standard
WEB\Internet Browser. TNG is accessible from anywhere on the network,
you just need to enter the IP address and port number of the PC where
TNG is installed on, in the address section of the web browser (eg. 127.0.0.1:7080).
Also See: Can I run TNG remotely?
