Topaz Next Generation (TNG.exe) released. Version : 1.0.5.6
Postby Belinda Frick » Mon Nov 15, 2010 1:41 pm
Release Notes
This version will be emailed to registered clients at 19:00 on 29-Feb-2008.
Subject : Reading Data from Files
Motivation
TNG must be able to get rawdata from files to allow for PABX's that does not
have a serial or network interface but instead dumps a file to disk.
Completion
A new option was added in the TNG standard version, you can now select File Reader under
Communication Mode and then specify a filepath and filename. It also allows for using
a * character as a mask in the filename, therefore allowing the reading of multiple files
in the same folder.
