TNG updates for Windows and Linux
Postby Belinda Frick » Mon Nov 15, 2010 1:43 pm
  • For Windows:
    (assume Version 1.0.5.6.dtx)
    TNG version updates for windows is in .dtx format.
    To install the TNG update:
    Make sure everyone is logged out of TNG.
    Run the .dtx file on the TNG host pc.
  • For Linux:
    Note: You may save the update file anywhere on the Asterisk box, but
    when you run the update command you must run it from the folder where
    the update file is saved.
    (assume TNG Update file to be : replacefiles tng-1.0.5.6_za_update-1.rpm
    Replace 1.0.5.6 with your tng version)
    TNG version update for linux is in .rpm format.
    Run the .rpm file on the TNG host pc.
    Do not run this update on a server that doesn't have TNG installed. It will result in a broken TNG installation.
    rpm -i --replacefiles tng-1.0.5.6_za_update-1.rpm
    Please Note: It is possible that the linux install might complain about
    dependencies missing, then you just add –nodeps and run it as:
      rpm –i –-replacefiles –nodeps tng-1.0.5.6_za_update-1.rpm
