TNG 1.0.5.6:Changing the import file name while importing
Postby Belinda Frick » Mon Nov 15, 2010 1:55 pm
If TNG is busy importing a file and you change the file name and
click on apply, if the first file is huge - it can seem like TNG
is hanging. It will complete the import of the first file and
then commence with the 'new' file as specified.
We do not suggest changing the file name while busy importing
another file.
Also note that only the current file name (specified in Communication Configuration)
will be moved at 01h00 to the 'Processed' folder.
We suggest that when loading more than one file to use the wildcard option (eg. *.txt)
and all the .txt files in the specified location will be imported and moved at 01H00.
