Release Notes: TNG version 1.0.6.0
Postby Belinda Frick » Mon Nov 15, 2010 1:57 pm
Released: TNG Version 1.0.6.0 (10 September 2008)
Features:
NB: TNG's export file names and locations have been changed.
Exports will now happen to a day-stamped file directly in the export folder and a day-stamped
folder will not be created anymore e.g: c:\program files\datatex\tng\export\20080910.txt
or Linux: /opt/datatex/tng/export/20080910.txt
Additional information has been added at the back of the export data format.
Additional Options was added to the Call Outcome selection criteria for reports.
TNG now supports co-branding. Dealers can contact our Sales Office for more information.
The Speed of browsing the user interface over a WAN has been improved.
A TCP Keep Alive option has been added to provide earlier detection when a connection to a network PABX has been dropped.
Changing the TCP Listen ports for integration will now take affect without having to restart TNG.
The minimum percentage of memory to use for TNG has been decreased to 5% on Linux.
Ratebook and Exchange File versions are now written to logfile when the file is loaded.
The Message displaying remaining and stored data on the Login page has been made more descriptive.
Additional Information Logs pertaining call saving and loading has been added.
Plugin rules can now be configured to also apply to internal calls.
Support for the TNG Barring Utility was built in.
Support for the TNG Enterprise Edition was built in.
Fixes:
The call record sequence number will only increment when a call has been validly parsed as a new call.
The bug introduced in version 1.0.5.8 whereby you were unable to delete extensions has been fixed.
Reports will be checked for validity before the report is generated for example when a refresh is done.
This was a problem under certain Linux distributions which could have caused TNG to stop working.
