Installation of the AVR (Active voice recorder)
Postby Belinda Frick » Thu Dec 09, 2010 2:14 pm
***AVR (Active Voice recorder) has been discontinued and replaced with ONYX. Please contact your dealer for upgrade options.***
To start the AVR double click on the executable or the shortcut.
At the top left there is a play and stop button.
If you click on the play button and it turns grey,
the AVR will start recording when the trigger level is exceeded.
The trigger level is the red and yellow bar in the middle,
adjust this bar to let the recordings start at the correct noise level.
The stop button will stop the AVR from recording automatically.
On the top right hand side there is a play, stop and question mark button.
This is for playback of a recording:
- First click on the question mark
- and choose a recording to play.
- Click the play button to listen to the recording
- and stop to stop playback.
If the play button is green, it is not receiving a recording.
Check in the log file for a error, C:\Program Files\Datatex\AVR.
ALSO SEE: Nothing happens when I click on record on the SLVR / AVR
At the bottom right there is a options button. This button will let you
configure the option that were explained below.
Example of INI file
TRIGGERLEVEL=55
SILENTTIME=40
WRAPUPTIME=7
SOUNDPATH=C:\Program Files\Datatex\AVR\Data\
AUTOSHOW=1
MINLEN=15
AllowShutdown=1
;POSSIBLE SAMPLERATES can be 8000,11025 or 22050
SAMPLERATE=8000
AUTOCLOSE=1
; GSM or WAVE format
WaveFormat=GSM
; Bitspersample 8 or 16
BITSPERSAMPLE=8
; Chanels 1=mono and 2 = stereo
CHANNELS=1
WAVEINDEVICE=0
AUTOSTART=1
[STATION]
EXTENSION=201
ASKFORFILENAME=1
What the fields mean
TriggerLevel = Gets changed from the program by dragging the scrollbar in the top
right corner.
SilentTime = After this amount of silence the recording will stop.
WrapupTime = After the recording has stopped the user has this amount of time to
enter notes.
SoundPath = Where the recording should be saved before FTP.
AutoShow = If the SLVR should popup when start recording. 0 = false, 1= true.
MinLen = The minimum length that a recording must be before it is accepted.
AllowShutDown= If the agent is allowed to shutdown the SLVR. 0 = false, 1= true.
SampleRate = The samplerate the SLVR records in.
AutoClose = If the SLVR should hide when finished recording.0 = false, 1= true.
WaveFormat = In what format the SLVR should record the file.
BitsPerSample= How many bits per sample should the SLVR record at.
Channel = 1 = Mono, 2 = Stereo.
WaveInDevice = This is the device the SLVR should use to record, change this from
properties screen on the supervisor.
AutoStart = Start recording when voice is detected. 0 = false, 1= true.
Extension = The extension of the phone where the SLVR is installed.
AskForFilename = 0 = false and 1 = true. The AVR will prompt you for a file to save
the recording with.
