- ONYX uses the soundcard of the USBTap to make the recording, but for playback it uses the soundcard of the PC. Therefore when using a USBTap, you need to select the soundcard of the PC for playback and the USB Tap Soundcard for recording.
- Select a different audio device by going to the
Start menu -> Settings -> Control Panel -> Sounds and Audio Devices -> Audio tab.
The SoundPlayback option should be changed from the default
e.g USB Audio Codec to another device.
or
Right-click on the speaker-icon in the bottom right-hand corner of your screen.
Select Options -> Properties:
Tick "Recording", select the "USB Audio Codec".
Tick "Playback", select the soundcard of your PC.
This is for recording and playback.
- ONYX(Version 1.*): Now close Onyx and reopen.
- ONYX(Version 2.*): Stop/start the ONYX recording service or reboot the PC(to stop/start the service).
