No, do not delete anything in the ONYX folder as
this might result in errors.
To erase a specific recording at a later stage:
Right-click on the recording on the "PLAYBACK" tab.
Then choose the "DELETE" option. This will erase
the entire record (recording file, screenshots and notes).
NOTE:
You have 2 options on whether to save a recording
or not.
These choices can be made in the "SETTINGS" tab
by either ticking or unticking the "PROMPT TO SAVE
RECORDINGS" tick box.
1. Unticked
ALL recordings will be saved with a duration exceeding
the "Do not save recordings shorter than X seconds"
section.
2. Ticked
At the end of the recording (after silence time and
wrapup time reached a duration of zero) a screen will
ask whether you want to "SAVE" or "CLOSE".
If you click on the "CLOSE" button or if the time
(count-down timer of 30 seconds) reaches zero, the
recording will not be saved.
If you are struggling to find the recording
you want to delete:
ALSO SEE:
Searching for an ONYX recording.
