On Windows XP the system restore function seems to slow down
some applications in the Program Files folder.
Onyx is affected by this facility. The following can be done
to prevent performance issues:
Move the application to a folder outside the Program
Files folder. (Remember to change all the configuration settings
when doing this)
Disable the System Restore functionality of Windows. This may
prevent you from recovering your Windows if it is corrupted.
