Does ONYX have security (Password protection) for recordings
Postby Belinda Frick » Mon Dec 13, 2010 10:27 am
OVERVIEW
You can setup a security password on the playback screen to prevent any unauthorized access
to recordings in ONYX.
Follow these steps:
Click on the Settings tab on the ONYX main screen.
Then click on 'Password' (icon of a lock).
If it is the first time a password is being enabled, leave the 'old password' section blank.
Only enter your password in the 'New' and 'Confirm' password fields.
Click on the tick icon.
Remember to click on APPLY (the 'tick' icon top of ONYX screen next to the password icon)to save your settings.
Now that your password has been saved, each and every time you access the playback screen and settings screen you will be prompted for the password. Enter your password and click 'OK' to access the recordings.
If you wish to disable the password feature, enter your password in the 'Old Password' section only leaving the other fields blank.
Remember to click on the 'Apply changes' tab to save your settings.
