Release Notes
This is still a beta release.
Completed Tickets
Subject: Onyx 2 screen position
Motivation
The users had 2 screens and ONYX2 would pop up in the middle of the two screens each time.
Even if you moved it to some other part of the screen. Subsequently all the child windows from ONYX 2
would be split across the two screens.
Completion
Onyx2 will now display in the center of the main screen.
Subject: Onyx 2 ini filename
Motivation
There is no ONYX.ini. The INI used to configure ONYX2 is USBClient.ini.
Completion
The Onyx2 ini filename is now ONYX.ini
Subject: Onyx 2 popup
Motivation
When ONYX is set to pop up and there is an active window open, I.E IExplorer it pops up behind
the IExplorer window, still hidden from view.
Completion
Onyx2 will now pop up in front of the active window.
FEATURE Tickets
Subject: Onyx 2 Tray icon
Motivation
The Onyx2 tray icon does not indicate whether Onyx2 is busy recording.
Completion
Onyx2's tray icon now indicates if Onyx2 is recording or not.
Subject: Onyx 2 password protected search page
Motivation
Currently, if a password is set, it is not required when searching for or deleting recording.
Completion
If a password is set, it will be required when searching for recordings.
Subject: Onyx 2 recording playback without a tap
Motivation
Currently Onyx 2 can playback recordings without a USB tap being present.
Completion
Onyx 2 will only playback recordings if a USB tap is present.
Subject: Onyx 2 password protected settings page
Motivation
Currently, if a password is set, it is not required when changing Onyx 2 settings.
Completion
If a password is set, it will be required when changing settings.
