Windows 7 updates reverted settings
Postby Therlow » Wed Aug 29, 2012 2:15 pm
Please note that Windows 7 sometimes revert the settings for the usb tap.
Right click on the volume icon and click on recording as per below.
Check for the usb audio codec device and double click.
Then
Corrected the boost to between 1-5
Then
Correct the mono to stereo cd quality
Therlow
Re: Windows 7 updates reverted settings
Postby Therlow » Wed Aug 29, 2012 2:17 pm
Also restart the machine thereafter.
Therlow
