Changes for the Ruby supervisor
Postby Belinda Frick » Tue Dec 07, 2010 10:01 am
2.1.2.0
Now shows "disconnected" on status line instead of "connected" when a
logout instruction is received from Ruby.
2.1.2.1
Does not crash on startup when not logged in, now uses "Unknown" as
user name.
2.1.2.3
Removed all tables except tblTemp (used for report) and tables used in
configuration screen.
2.1.2.6
"Agents logged in" bar on main screen now turns red if value drops below
amount specified in configuration.
Fixed long-outstanding bug where Ruby slows down when Supervisor is
running for a long time.
Fixed error about exceeding licensing when editing agents.
Fixed minor bug in reports and graphs that the date settings would not
always take effect when clicking on "View"
You can now sort the agent list on the main screen by clicking on the
column headers
The first group in the group list on the main screen is selected by
default
Changed Erlang screen to be a little more user-friendly
Now shows recommended trunks in bold red
Descriptions changed
Export the data to a CSV file, can be loaded in spreadsheet applications
"Use busiest hour" system changed on Erlang screen:
Select the hour to use from a grid, sorted by Erlangs
Select the date range to use for the busiest hour
2.1.2.8
Changed login dialog to not be resizable
2.1.2.9
Fixed bug in group configuration, only one group would show
Fixed bug in temporary table for Group data report
Now creates INI File if needed
Agent configuration window now shows selected group
2.1.2.11
Added "Marks" on Series tab for graphs, allows hiding of labels
Fixed bug where all series in legend were the same as series 1
2.1.2.13
Added Group data report in 15-minute intervals
Added two new fields to group data report (not usable on LG)
Re-arranged Group Data report to be more readable
2.1.2.15
Changed Erlang screen to be simpler
2.1.2.16
15-minute report
2.1.2.17
Make Graph screen a bit simpler
2.1.2.18
Fixed bug in stats graphs - now doesn't include data from first 15
minutes of ending hour
2.1.2.19
Released version
