How do I check if I am getting ACD data in RUBY Sever?
Postby Belinda Frick » Wed Dec 08, 2010 10:49 am
RUBY SERVER -> SYSTEM,
double-click on the status bar at the bottom of the screen.
If you do a test, for example, log the agent in,
you will see the ACD data.
If no data is display, then the PABX unit is not configured
to give off the required data.
