The following programs have to be configured to have a working setup.
You must use the PMitel_3300ICP2_MILU.DLL plugin version 2005.3.16.0 or Higher.
Create an INI File in the PABX3 Folder: AMitel_ACD.ini
___________________________
[AMitel_ACD]
MULTIGROUP=1
GROUPS=6,7,8
List the ACD Groups, comma seperated here. If this number is found at the start of an extension
it will be stripped off and placed in the group Field.
