Internal gds software consistency check...can't continue after bug check
The database is damaged and can't be backed up.
Make sure you've made a backup of the database.
Then try doing "gfix -m -f ruby.gdb", and then do
"gbak -b -v -limbo -ignore -garbage ruby.gdb ruby.gbk".
If this fails, the database is beyond repair
and you will have to replace the database with a
new, blank database and configure everything again.
Contact Datatex for a new database.
