RUBY and SAMSUNG 7400: new DID number added to PABX
Postby John Richard Procter » Tue Aug 16, 2011 12:17 pm
They have anew DID that has been added to the PBX and they need to have
the software configured to work properly.
Required information:
The DID : [2011]
The Group where the calls will be routed too [5015, Admin, Group 1]
The Name of the new DID [Warrenty]
After hours Voice mail number for this DID. [3550]
PABX3:
Add the DID to the DID.txt files in the PABX3 folders.
Restart the PABX3
SMDRLink:
Add the DID to the DID.txt files in the SMDRLink folders.
Stop and then start the SMDRLink service
RUBY 2:
Run the Ruby Config to configure the system.
Add the DID lookup to the "Group lookups" Tab. [2011 and 1]
TOPAZ - EXTERNAL:
  • Add User details
    Go to the Data area.
    Add a new SECTION for the new DID [Warrenty]
    Add a new USER for the DID. [Warrenty]
    Set the BRANCH to "Call Centre"
    Department as they require [Admin]
    (Group 1 = Admin, Group 2 = Retail and Group 3 = Returns)
  • Add Account code
    Add an ACCOUNT CODE with the same value as the DID. [2011]
    Allocate the USER you just created to the account code.
  • Add reports
    Go to the reports
    Duplicate the existing reports and change the duplicates to the new DID
    values.
    Setup the scheduled reports to email to the appropriate people
TOPAZ - INTERNAL:
There should be nothing required here for a new DID
