How can I check whether the Samsung OfficServLink is connect
Postby John Richard Procter » Tue Aug 16, 2011 12:22 pm
How can I check whether the Samsung OfficServLink is connected and receiving data from the PABX?
How do i check if the OfficeServLink is connected to the TSP?:
  • Click on START -> ALL PROGRAMS -> Samsung Open TSP driver -> Switch message monitor
  • When the Switch message monitor opens it will automatically display the connection status of the TSP
    and whether its receiving data.
    To reconnect the Samsung OfficeServLink to the TSP:
  • CLick on START -> Connection Utility.
  • When prompted, click on Reconnect
  • Please make sure that all TAPI applications are not running during the reconnection.
  • Once the Open TSP is connected you may start your tapi applications
