transferred call on the agents extension.
To compare TOPAZ with RUBY keep in mind that:
- TOPAZ takes a full day and not for example 22-06-2004
07:00 AM until 05:00:00 PM as RUBY can. - Also RUBY handles only incoming calls.
Select only incoming calls in your TOPAZ report. - RUBY is setup to monitor a Call Centre Group, example
Sales. TOPAZ is divided into groups using Branch, Department
and Sections. - Check which action your PABX gives
- ALSO SEE: TOPAZ report by action code
Some PABX's gives the call group in the reference field - ALSO SEE: TOPAZ report by reference code
TOPAZ:
Depending on the actions your PABX uses, you can pull the
reports below to compare your data.
If your TOPAZ monitors all extensions in the company and not
just your Call Centre group, make sure that your TOPAZ
"section" matches your extension group for the Call Centre.
If your PABX unit gives off the call group,you can use the
call group in stead of Branch, Department and Sections.
DATA-> LOOKUPS-> SECTION-> Group your extension of the call
centre together as for example "CallCentre".- Setup a report in TOPAZ for TRANSFERRED calls.
Click on the "+", now enter your report heading under Description,
example All Transferred Call by User.
Report options : tick "summary" and "only incoming"
Select records : Yesterday
Summary Report Format : Call Category
Order by : Group
Group by : User
Maximum Records : 0
Field Selection : Action, =, I_TRANSFER
Only Select These : Select All_Branch_
Select All_Departments_
Select "CallCentre" - Setup a report in TOPAZ for UNANSWERED calls.
If a call was transferred and not answered, it will be marked as
unanswered. If a call was transferred and ring at an extension
and another extension picks up the call, there will be
two call records, one unanswered and one answered call.
Order by : Group
Group by : User
Maximum Records : 0
Field Selection : Action, =, I_UNANSWER
Select "CallCentre" - ALSO SEE: Topaz Report for Ringtime
- RUBY:
View a Group Report per hour of day. Make sure that the date matches
your TOPAZ report and that your time is set from 00:00:00 AM until
23:59:59 PM.
The "Agent" column will have the TRANSFERRED call and the UNANSWERED call
under "Total" for "Calls", since the PABX gives off two call records.
ALSO SEE: An explanation of the different fields in the group report per hour of day.
