RUBY opening error: ...opening table. Application closing
Postby John Richard Procter » Mon Aug 22, 2011 12:23 pm
RUBY opening error: ...opening table. Application closing down. Transaction is not active.
  1. Make sure the RUBY data path in the ini is pointing to the correct
    location. It must use the network path, not local.
    ruby.ini:
    [RUBY]
    Database=gem:/drive2/Interbase/Ruby/ruby.gdb
  2. Make sure you are using latest version of the software, at least
    'rby-server-update-2_3_10_1.exe' and 'rby-supervisor-update-2_3_10_0.exe'.
    If you get a 'inconsistancy' error when opening RUBY it means that the
    database is damaged. Please do a backup and restore.
ALSO SEE: Fixing an Interbase database
