violation of PRIMARY or UNIQUE KEY constraint "INTEG_+46" on table "AGENTMASTER"
Suggestions:
- Check that your agent name and/or extension is unique.
- Check that only one instance of the 'config.exe' is running on the RUBY server
- The database could be damaged. You will need to do a backup and restore of the database.
NOTE: Please contact Datatex for a call out. - Check that link between Agent and Extension & IPs tab is showing the information.
STATUS OF POST: INCOMPLETE!!
