You can export data from Custom Reports in TOPAZ.
Go to [REPORTS -> CUSTOM REPORTS].
Create the report with the data you need to export. Click on VIEW to check it.
If you are happy with the report,
to export this report to EXCEL,
click on the EXPORT button.
You will be prompted for a file path and file name,
the default is topaz.csv in the C:\temp folder.
You can enter your own csv file name
and browse for a different folder to save it to,
example C:\My Documents\MyTopazReport.csv.
When you open the file in EXCEL, you must select the
columns you need.
