Printing issues with Topaz
Postby Belinda Frick » Tue Nov 23, 2010 3:49 pm
When printing and the reports cut off on the right or bottom of the page.
Try the following:
Windows:
Ensure that the Windows printer settings is as follows:
- your paper size is set to A4 on the printer settings.
- printer properties : Set to A4.
Restart Topaz if you have changed any of the settings.
If this fails, try updating your printer driver.
The printer:
The printer must be able to print to paper size A4.
Make sure the printer is set to print to paper size A4.
TOPAZ:
Make sure you are using at least TOPAZ 1.7.0.4.
ALSO SEE: Reports don't print for Topaz, but all other applications print
