Cellular calls with a duration of more than a minute
Postby Belinda Frick » Thu Nov 25, 2010 12:16 pm
Custom Report grouped by Call Type, duration is more than one minute for the month:
Click on the "+", now enter your report heading under Description.
Report options : Summary
Select records : Last Month
Summary Report Formats : Call category
Order by : Calls
Group by : CallType
Maximum Records : 0 (for all records)
Field Selection : Seconds, >, 60
(all call with duration over 60 seconds
will be in report).
*** This report will group all the calls made per CallType for the Call Category.
Call Category = Incoming, Local, National, International, Cellular & Other.
Call Type is the Call Costing in use, example:
- TelkomA=Local, TelkomB=National
- Cellular can be calls thru the Telkom line (Cellular)
or the router (Other).
