TOPAZ Batch Reports and e-mails
Postby Belinda Frick » Thu Nov 25, 2010 12:38 pm
Try setting up all the reports in one batch.
Then one report will be created after the previous is done.
If you have more than one batch, try setting it up so that
there is a gap between execution of the batches.
You will receive an email for each report in the batch.
The email will be send after the report is generated.
