CELLULAR phonecalls by extension or Account Code / User
Postby Belinda Frick » Thu Nov 25, 2010 12:46 pm
1. Calls to cell phones from extensions:
Click on the "+", now enter your report heading under Description.
Report options : Summary
Select records : All
Summary Report Formats : Detail with Summary
Order by : Group
Group by : Extension
Maximum Records : 0 (for all records)
Field Selection : CallType LIKE CELL%
Save your report with the tick mark.
Remember : The Description field may not be blank.
This report will only show
- for each extension starting on a new page
- all the cellular calls
- (costed at Telkom rates AND the Cell Router)
- made for your date period (Select Records)
The only further exclusion you can make is selecting the
branch / department / section at "Only Select These",
if you are using the branch / department / section
classification.
2. Calls to cell phones using account codes:
If you want to see all calls to Cellular numbers made
using an account code, use the same report setup, but
Group by : User
For this report to reflect the correct information you
must have the account codes setup correct,
ALSO SEE: Topaz Report by Account Code
3. Summary by extension of calls to cell phone
numbers with Telkom charge:
Summary Report Formats : 4. Call Category
Order by : Group
Field Selection : CallType = CELLLULAR
The "other" column shows calls through the cellular router.
The "cellular" column is calls via Telkom.
